Perform this procedure to remove a specific configuration file from Fabric IPsec Gateway Virtual Machine (VM).
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Remove the configuration file:
    remove WORD <1-255>
Remove configuration file "test" from Fabric IPsec Gateway VM:
Switch:1> enable
Switch:1# virtual-service figw console
Connected to domain figw
Escape character is ^Y
  <cr>
FIGW> remove test
The following table defines parameters for the remove command.
Variable Value
WORD <1-255> Specifies the configuration file name that the system removes from Fabric IPsec Gateway VM.
